AnsweredAssumed Answered
ArcEngine import tiff wrong colours
Question asked by askltd on Mar 17, 2016
Latest reply on Mar 22, 2016 by modybsystematics-co-il-esridist
Using Arc Engine, I have produce a map handling product for our clients. It takes their low level mapping and produces bit maps at diffferent scales though an automatic procedure.
The software produces Geo Tiff files. I have checked these files and they are correct, but when I do an automatic import of the bit maps, some of the files have their colours changed.
There isn't any rendering on those files, as they are on their own separate layer files. If I clear the map down, and run the import again, different bitmaps have their colours wrong.
I am using the following code to import the tiff file
private ILayer AddBitmap(string mapDirectory,string imageDirectory, string sFile, object minimum, object maximum, IGroupLayer groupLayer)
            IRasterLayer prlyr = null;
            try
                WriteLog("loading " + sFile);
                string layerName = System.IO.Path.GetFileNameWithoutExtension(sFile);
                string lName = imageDirectory + @"\" + layerName + ".lyr";
                if (mapDoc != null)
                    int c = mapDoc.get_Map(0).LayerCount;
                    for (int i = 0; i < c; i++)
                        ILayer layer = mapDoc.get_Map(0).get_Layer(i);
                        if (layer.Name == sFile)
                            return null;
                IWorkspaceFactory pWsFact;
                IRasterWorkspace pWs;
                IRasterDataset pRasterDataset;
                //Open the workspace
                pWsFact = new RasterWorkspaceFactoryClass();
                pWs = pWsFact.OpenFromFile(imageDirectory, 0) as IRasterWorkspace;
                //Open the raster dataset
                pRasterDataset = pWs.OpenRasterDataset(sFile);
                //Open the raster layer
                prlyr = new RasterLayerClass();
                prlyr.CreateFromDataset(pRasterDataset);
                ILayerFile layerFile = new LayerFileClass();
                layerFile.New(mapDirectory + @"\" + layerName + ".lyr");
                layerFile.ReplaceContents(prlyr);
                layerFile.Save();
                int index = axMapControl1.LayerCount;
                if (groupLayer == null)
                    axMapControl1.AddLayer((ILayer)prlyr, index);
                    if (mapDoc != null)
                        mapDoc.get_Map(0).AddLayer((ILayer)prlyr);
                else
                    groupLayer.Add(prlyr as ILayer);
                //Thread.Sleep(2000);
                 if (maximum != null)
                    ((ILayer)prlyr).MaximumScale = Convert.ToDouble(maximum);
                if (minimum != null)
                    ((ILayer)prlyr).MinimumScale = Convert.ToDouble(minimum);
            catch (Exception ex)
                WriteLog("error of " + ex);
                MessageBox.Show("Error\n" + ex.Message);
            return prlyr;
Outcomes
