How to put Infowindow and Tooltip
2312
03-17-2016 10:54 AM
EvelynHernandez
Occasional Contributor III
Im making an app which i have added some dynamic layers to the map, but for some reason i cannot put the :
infowindow (in onclick) and a tooltip (in mouseover).
Can anyone tells me what im doing wrong or provide any example of how to do this? (I already try using the examples in the Samples | ArcGIS API for JavaScript  for infowindows)
It will be very usefull.
Thanks a lot
Im developing with reactjs (es6) , webpack srv and i put the arcgis_js_api in my working webpack server.
I separate the map in another javascript file
function mymap(){
  var map;
  return {
    createMap(div){
      map = new esri.Map(div, {
            basemap: "topo",
            center:[-71.2905, -33.1009],
            zoom:9,
            logo: false
      return map;
    getMap(){
      return map;
    onClick(){
      map.on("click",(mouseEvent)=>{
        return console.log("thinking on map onClick for infowindow");
export default mymap();
The code for my component where i set up the map is:
import React from 'react';
import ReactDOM from 'react-dom';
import token from '../services/token-service';
import layers from '../services/layers-service';
import StatisticsToolbar from '../bundles/statistics-toolbar';
import mymap from '../services/map-service';
import MyGrid from '../bundles/myGrid';
class Interruptions extends React.Component {
  constructor(){
    super();
    this.onClick = this.onClick.bind(this);
    this.onClickToggle = this.onClickToggle.bind(this);
    this.onClickStatistics = this.onClickStatistics.bind(this);
    this.searchMassive = this.searchMassive.bind(this);
  componentDidMount(){
    var map = mymap.createMap("myMapDiv");
        map.disableKeyboardNavigation();
    var myDynamicSedLayer = new esri.layers.ArcGISDynamicMapServiceLayer(layers.read_dyn_layer_PO());
    var myDynamicBTLayer2 = new esri.layers.ArcGISDynamicMapServiceLayer(layers.read_layer_BT());
    var visibleLayers = [1];
      myDynamicBTLayer2.setVisibleLayers(visibleLayers);
      map.on("click",(evt)=>{
        //TEMPLATE PARA MOSTRAR INFOWINDOW SUBESTACION DE DISTRIBUCION (0)
        var chqSubestacionDistribucionTemplate = new esri.InfoTemplate();
         chqSubestacionDistribucionTemplate.setTitle("<b>SSEE: ${ARCGIS.DBO.SED_006.codigo}</b>");
         var chqSubestacionInfoContent =
        "<div style=padding-top: 10px;>Nombre: ${ARCGIS.DBO.SED_006.nombre}<br></div>" +
        "<div style=display:inline-block;width:8px;></div>"+
        "<div style=padding-top: 10px;>Alimentador: ${ARCGIS.DBO.SED_006.alimentador}<br></div>"+
        "<div style=padding-top: 10px;>Comuna: ${ARCGIS.DBO.SED_006.comuna}<br></div>"+
        "<div style=padding-top: 10px;>ID Orden: ${ARCGIS.DBO.POWERON_ORDENES.id_orden}<br></div>"+
        "<div style=display:inline-block;width:8px;></div>";
      chqSubestacionDistribucionTemplate.setContent(chqSubestacionInfoContent);
        // show info window
        myDynamicSedLayer.setInfoTemplates({
          0:{InfoTemplate: chqSubestacionDistribucionTemplate}
      map.addLayer(myDynamicSedLayer,2);
      map.addLayer(myDynamicBTLayer2,1);
NOTE: My directoryFile is in the attachment.
EvelynHernandez
I fix this problem (but just for infowindow):
var myDynamicSedLayer = new esri.layers.FeatureLayer(layers.read_layer_interr_sed(),{
       mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
       infoTemplate: myinfotemplate.getSubFailure(),
       outFields: ["*"]
Where myinfotemplate.getSubFailure() is a infotemplate-service where i get the infotemplates customized by me.
Example:
function getInfoTemplate(){
  return {
    getSubFailure(){
      let chqSubInfoTemp= new esri.InfoTemplate();
      chqSubInfoTemp.setTitle("<b>Codigo Subestación: ${ARCGIS.DBO.SED_006.codigo}</b>");
      let chqSubInfoContent =
      "<div style=padding-top: 10px;>Causa: ${  ARCGIS.DBO.POWERON_ORDENES.causa}<br></div>"+
      "<div style=padding-top: 10px;>Comentario: ${ARCGIS.DBO.POWERON_ORDENES.comentario}<br></div>";
      chqSubInfoTemp.setContent(chqSubInfoContent);
      return chqSubInfoTemp;
EvelynHernandez
       outFields: ["*"]
Example:
  return {
    getSubFailure(){
