Looking for a Base Map
4476
6
03-15-2016 12:05 PM
EricBianchi1
New Contributor III
Hello all,
I am working on a project where I need to use a base map and the maps that are in the default base layer tab are not exactly what I want to use. For a couple reasons, such as: not being up-to-date enough, or not the right layout. The map is being used as the basemap to our parking restriction graphical image.
I know that one has the ability to draw in layers from the web by searching, but the ones that I found are not ones that are appealing to me. I was wondering if I could draw in google maps, or maybe just hide some of the many images in "open streets" (hide the picnic benches, parking image, restuarant etc).
AdrianWelsh
MVP Honored Contributor
Hi Eric,
Where are you located? Sometimes that has a big factor on what you can and cannot use. I'm not sure about being able to turn off certain features within Openstreetmap.
It seems like the Google question is brought up a lot and there never seems to be a good answer to that question. There is a link for using Google Maps Layer for ArcGIS JavaScript API but it may not work now?
http://www.arcgis.com/home/item.html?id=a8f78cc6adea48cb8e962d7e36b9d010
Also, there is some info in this post from Kevin MacLeod:
https://community.esri.com/message/547361#comment-574467
I actually responded to a post last month about this (I kind of forgot about it...)
https://community.esri.com/message/591148#comment-591268
I hope you find something that works!
EricBianchi1
New Contributor III
Thank you, I will look into this.
Have a great day!
AdrianWelsh
Just to follow up, did any of these options work out?
Salmon_ArmBC
New Contributor III
Hi Eric,
I'm also curious where you are and how you made out. I'm in BC, Canada. Our Provincial government has some great resources for base maps. Maybe you could find something similar:
BC Web Map Library - Datasets - Data Catalogue
EricBianchi1
New Contributor III
I'm at Virginia Tech, Civil engineering. I am looking into what you
provided, but I have not decided on one choice yet. Also I went to Montreal
last summer, I loved it there. Thanks for being so helpful. I'm sure I will
have many more questions in the future.
Salmon_ArmBC
New Contributor III
Good luck with your project!
I'm jealous that you've been to Montreal. Unfortunately, it is about 4000 km (roughly 2500 miles) from me so I've never been. I live just a few hours from Vancouver, though. Such a beautiful city!
