Local Server on Red hat 7.1x64
4282
03-15-2016 08:34 AM
ValerioQuintarelli
I'm using the esri QT Runtime 10.2.6 on Red Hat 7.1 x64, with the latest version of qt libraries(5.5). I was trying the example on esri site Dynamic map layer (https://developers.arcgis.com/qt/cpp/sample-code/dynamic_map_layer_sample.htm) and map control does not display anything, those are the results.
This is the log file
Starting server
Local server process started
'apppid' = '8433'
'cleanuponshutdown' = ''
'crashdump' = 'full'
'datadir' = '/tmp'
'enablehtmlviews' = ''
'logging' = ''
'onlinux' = ''
datadir does not exist, creating: "Z:\tmp\arcgisruntime_8"
Message : DataDir : Z:\tmp\arcgisruntime_8
Enabling logging
Message : Log file path : /tmp/ArcGISRuntimeLogs/arcgisruntime_8.log
Message : AppDataLocalDir : C:\users\valerio\LO~SSGOF\ArcGISRuntime
Message : AppDataRoamingDir : C:\users\valerio\LO~SSGOF\ArcGISRuntime\Roaming
Message : AppDataCommonDir : C:\users\valerio\LO~SSGOF\ArcGISRuntime\Common
Message : MyDocumentsDir : C:\users\valerio\LO~SSGOF\ArcGISRuntime\Documents
Message : CrashDumpPath : Z:\tmp\ArcGISRuntimeErrorReports
Message : Licensing level : demo:standard:0
2016-03-11 11:57:32,322: INFO  rid=    'server'  WebServer - Starting server on port 50000
2016-03-11 11:57:32,322: INFO  rid=    'server'  PionScheduler - Starting thread scheduler
2016-03-11 11:57:32,323: INFO  rid=    'server'  WebServer - Added request handler for HTTP resource: /ySbCq9/outputdir
2016-03-11 11:57:32,323: INFO  rid=    'server'  WebServer - Loaded static web service for resource (/ySbCq9/outputdir)
2016-03-11 11:57:32,323: INFO  rid=    'server'  AdminWebService - Creating.
2016-03-11 11:57:32,324: INFO  rid=    'server'  WebServer - Added request handler for HTTP resource: /ySbCq9/arcgis/rest
2016-03-11 11:57:32,324: INFO  rid=    'server'  WebServer - Loaded static web service for resource (/ySbCq9/arcgis/rest)
2016-03-11 11:57:32,324: INFO  rid=    'server'  WebServer - Added request handler for HTTP resource: /static
2016-03-11 11:57:32,325: INFO  rid=    'server'  WebServer - Loaded static web service for resource (/static)
Message : Server version : 10.2.6.4161
Message : Server listening on : http://127.0.0.1:50000/ySbCq9/arcgis/rest
2016-03-11 11:57:34,426: INFO  rid=1   'server'  AdminWebService - POST admin/createService?filePath=/home/valerio/arcgis/runtime_sdk/qt10.2.6/sdk/samples/data/mpks/USCitiesStates.mpk&maxRecords=1000&name=USCitiesStates.mpk&type=MapServer&f=json
2016-03-11 11:57:34,428: INFO  rid=1   'server'  mpk - Creating.
2016-03-11 11:57:34,428: INFO  rid=1   'server'  mpk - Create
2016-03-11 11:57:34,428: INFO  rid=1   'server'  mpk_host - Creating.
2016-03-11 11:57:34,432: INFO  rid=1   'server'  mpk_host - Launching.
2016-03-11 11:57:34,510: INFO  rid=1   'server'  mpk_host - Launched process 47
what is the problem for you?
LucasDanzinger
Esri Frequent Contributor
Is the path to the MPK correct? It seems like it starts up the local server itself, but the service is not starting.
ValerioQuintarelli
Hello Lucas,
Yes, the path is correct and the same example works in the red hat 6.6, I
tried to control of the RESTservice page, and I get this:
"crashed" : false,
"createParams" : {
"filePath" :
"/home/valerio/arcgis/runtime_sdk/qt10.2.6/sdk/samples/data/mpks/USCitiesStates.mpk",
"maxRecords" : "1000",
"name" : "USCitiesStates.mpk",
"outputDir" : "Z:/tmp/arcgisruntime_8/USCitiesStates.mpk",
"type" : "MapServer",
"virtualDir" : "
http://127.0.0.1:50000/bvRtc0/outputdir/USCitiesStates.mpk"
"endpoints" : [
"processId" : -1,
"socs" : [
"createParams" : {
"filePath" :
"virtualDir" : "
"description" : "REST handler",
"errorReports" : [
"id" : "host",
"pid" : 46,
"status" : "Starting"
"starting" : true,
the service remains in the "starting" status.
2016-03-15 18:36 GMT+01:00 Lucas Danzinger <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from Lucas Danzinger
<https://community.esri.com/people/LDanzinger-esristaff?et=watches.email.thread>
in ArcGIS Runtime SDK for Qt - View the full discussion
<https://community.esri.com/message/595287?et=watches.email.thread#comment-595287>
LucasDanzinger
I missed this in the original title of the post, but The issue is likely the version of red hat you are using. With our 10.2.x release, we support 6.2-6.6. Please see the system requirements here - System requirements—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
Red hat 7 has been known to work with our API in general, but not with local server, due to wine compatibility issues. We are planning on targeting red hat 7 for our Quartz release, which comes out later this year.
-Luke
