How to filter ArcGIS Online resources by file/data type?
3955
8
03-15-2016 01:42 AM
YovavZohar1
Occasional Contributor III
Is there a way to filter the ArcGIS Online resources searches (arcgis.com in browser), directly, by certain file/data type?
The built in filters are more generic and when I'm searching for specific data, such as ArcGIS Pro Project Template or Layer Packages, I can't find any direct filter for that. This means that you have to go over a lot of irrelevant search results before you find what you want - even if you enter the data type to the search string.
Thanks in advance,
Yovav Z.
Tags (1)
KellyGerrow
Esri Frequent Contributor
You can search for specific item types by using the type parameter to define the type of content.
Example:
If you are looking for a project template about vehicle check points, enter: Vehicle type:Project Template into the search box. Ensure that you check the Show ArcGIS Desktop Content check box and you will see the returned search with the specified content.
For more information about search capabilities, see the following documentation:
Search:
http://doc.arcgis.com/en/arcgis-online/reference/search.htm
Item Types:
What can you add to ArcGIS Online?—ArcGIS Online Help | ArcGIS
Cheers,
Kelly
VenusScott
Have you tried using the AGOL assistant? This might be useful. We don't store data/files on AGOL so I've only searched for maps and apps...
ArcGIS Online Assistant
YovavZohar1
Yap, no solution here.
I think it should be an enhancement needed in the UI"
Adding advanced filter - by File/Data Type
KellyGerrow
Example:
Search:
Item Types:
Cheers,
Kelly
YovavZohar1
Great - That does the trick
Thanks Kelly.
I hope that all those advanced search flags will be combined into an Advanced Search button in the UI - it'll make life easier for less uptodate users like me
VenusScott
OK, how about this one. I'm requesting funding for the Pro version, but the free one might be what can assist you?
Admin Tools New - Geo Jobe
YovavZohar1
Thanks Venus,
Are the Admin Tools work on the organizational item?
I couldn't find Items outside of my organizational account.
Other thing is that the Item Type list is missing some types (probably needs update according to the AGOL supported Item Type list here).
Anyways, Kelly Gerrow's answer made the trick.
NeillJobe
Yes, Admin Tools for ArcGIS Online only works with content that you are an Administrator of (Your organization). You cannot find and administer items owned by others outside of your organization.
Also, new item types are being added daily as they become available through the API.
YovavZohar1
Thanks Neill
