Symbology Question
2192
6
03-14-2016 02:50 PM
PROBERT68
So when you create  an annotation layer that you can design and in it has an attribute field called "Status", which tells you to placed or unplaced the annotation to be display it or not to display it.
My question to you.  How do you turn off the symbology you set it up as a Layer whether they be a polygon, point, or polyline and you assign a new field column "Status" and add it Annotation Status as a Coded value domian.
I just did mine on my Campgound Labels point layer. When I select a point to tell that one to unplaced and it is still showing the icon ?
I do not want to delete the point, because I might need it later .
Salmon_ArmBC
New Contributor III
I think I understand what you're trying to say. Forgive me if I'm wrong!
Have you tried using a Definition Query on the Campground Labels point layer? Your query would be something like Status = Placed. That should hide the points as well as the annotation.
Salmon_ArmBC
New Contributor III
PROBERT68
I see. I will try and use that Definition Query you suggest that to me. I have several points that are group like Water, Trash, Restroom etc. I have about three different place for Water and two of them are ok but need the other Water that need to be turn off.
PROBERT68
That worked !
Salmon_ArmBC
New Contributor III
Great! Don't forget to mark the question as Answered!
PROBERT68
Since ESRI re-design it where do I mark answered ?
Salmon_ArmBC
New Contributor III
Someone already marked it as correct.
