alebar
An error was encountered while synchronizing with the config store
Discussion created by alebar on Mar 14, 2016
Latest reply on Mar 16, 2016 by rastrauch
We are using ArcGIS Server 10.2.2, on Windows OS, with MSSQL database. Everything worked perfectly but  few days ago map services were stopped and in log is warning:
An error was encountered while synchronizing with the config store. Failed to synchronize machine 'xxxxx' with the site. C:\Program Files\ArcGIS\Server\framework\runtime\ejbs\test_folder\service_name\Recycling (Access is denied)
Failed to synchronize machine 'xxxxxx' with the site. C:\Program Files\ArcGIS\Server\framework\runtime\ejbs\test_folder\service_name\Recycling (Access is denied)
Failed to stop the server machine "xxxxxxxx". C:\Program Files\ArcGIS\Server\framework\runtime\ejbs\test_folder\service_name\Recycling (Access is denied)
Response already committed. Cannot forward to error page.
Unable to process request. org.apache.jasper.JasperException: java.lang.NullPointerException
when service is started, after one minute is always stopped. Do you know what is this process? why it is crashed? services were published with the same as previous which are working correctly.
I had added security rules for everyone on folder "C:\Program Files\ArcGIS\Server\framework\runtime\ejbs\" but with the same error.
It seems that here is similar issue but I need to find out solution, not reinstall ArcGIS Server. (An error was encountered while synchronizing with the config store )
Outcomes
