Sending an MXD File: Maintaining Data Sources Which Exist on GIS Server
1959
03-14-2016 07:39 AM
JacobSnyder2
New Contributor III
I am currently attempting to send an MXD file which contains two data layers: one is a vectir polygon feature class which exists on an ArcSDE, while the other is a raster image that is located on an external ArcGIS Server. I would like to know how to send the MXD to someone else in a way that would maintain the data sources, and make it so that the person that I am sending this to will not have to fix broken data sources. Any help would be appreciated. Thanks.
-Jacob Snyder
AdrianWelsh
MVP Honored Contributor
Hi Jacob.
Consider using a Map Package. This way it keeps things together that you want together and you can choose whether or not you want to include Enterprise geodatabase data. Take a look at this article:
http://desktop.arcgis.com/en/arcmap/10.3/map/working-with-arcmap/creating-a-map-package.htm
AdrianWelsh
Hi Jacob.
JacobSnyder2
New Contributor III
This did exactly what I needed it to do. Thanks so much for your help.
AdrianWelsh
No problem! I am glad that it helped!
