alias for url in Query Result popup?
1844
03-08-2016 12:47 PM
HunterCarver
I'm trying to adjust the config_Query.json to use alias text instead of the full url link.  The in screen pop-up puts a "More_Info" text instead of showing the actual url but clicking it still takes you to the url.  I would like for the Query result to be the same.
"popup": {
        "title": "${WellName}",
        "fields": [
            "name": "API",
            "alias": "API",
            "specialType": "none"
            "name": "CurrentOperatorName",
            "alias": "Operator",
            "name": "Web_Link",
            "alias": "Web_Link",
            "specialType": "link"
            SOMETHING EQUIVALENT TO ALIAS HERE TO SHOW INSTEAD OF THE URL
So that it looks like this...
RobertScheitlin__GISP
Hunter,
  Obviously you have found that this is not a configurable option currently but you can male the code change to handle this by using the WAB Dev version and modifying the Widget.js file _createQueryResultItem function:
you would change the displayValue on line 4:
          else if(specialType === 'link'){
            if(displayValue && typeof displayValue === 'string'){
              fieldValueInWidget = '<a href="' + displayValue +
              '" target="_blank">' + displayValue + '</a>';
              fieldValueInPopup = fieldValueInWidget;
To get this alias from the widgets configuration json though you will have to make a couple more changes as will for that instead of using displayValue you can instead use fieldAlias.
