Domains greyed out...?
5676
03-07-2016 05:03 PM
HectorBorro1
Hello!
I'm trying to set domains to validate data entry into my collection method but are unable to do so because the buttons are greyed out:
Using the toolbox, I have created a domain
and added the Coded Values to the domain
But still the buttons are greyed out.  I have tried using different tables and it happens every time.
Any ideas on how to bring these buttons to life?
JayantaPoddar
MVP Esteemed Contributor
Try closing and reopening the project.
Found an issue in the release note
Release Notes—ArcGIS Pro | ArcGIS for Desktop
Changes made to domains, subtypes, and indexes using geoprocessing tools may not be reflected in the Design Views until the project is closed and reopened.
Think Location
JayantaPoddar
Think Location
HectorBorro1
mhh... I thought that was it, but still are greyed out and can't access them.
The domain seems to be correctly created as it appears on the list whenever I try to add a coded value to it.
Any other things that come to mind in order to be able to use the Domains on a table?
HectorBorro1
Also tried manually adding a domain to a field, but at no avail...
deleted-user-wgzH2d-p_0_f
New Contributor III
I would save your Output Table to your geodatabase, since that's where the domains are.
