Feature Layer/Service - Changing Symbols
2486
03-07-2016 11:39 AM
TyroneBiggums
Occasional Contributor III
My UI is set up with 2 lists. The first list shows the symbols of a selected feature layer. The second list shows options of what a symbol can be changed to.
For example, if the layer's renderer has a single picturemarkersymbol, the image displays in one list and the second list will show a series of graphics the user can select from.
Another example, if the layer's renderer has a collection of symbols (some picturemarkersymbols, some simplemakersymbols), all of the symbols are represented in the first list and the second list shows a series of images.
The idea is to select 1 from the first list and 1 from the second list. When the user submits, the new symbols should replace the old symbol.
I have everything done except for updating the symbols. Breaking down my code, and simplifying it, I have:
var path = jqueryUnorderedList.find('img')[0].attributes['src'].value;
map.getLayer(id).renderer.symbol.setUrl(path);
Nothing happens. The original PMS still exist on the map. What am I missing?
Also, what's the proper way to change renderer's completely? If I have a SMS and want to change to a PMS, do I need to setRenderer on the layer? I tried that too... nothing happens. Nothing on the map changes and nothing shows in the F12 console log.
Thank you for the help!
TimWitt2
Did you try and run yourfeaturelayername.redraw(); after you set the render?
Also this is what I use to set the render of a featurelayer:
FeatureLayer | API Reference | ArcGIS API for JavaScript
TimWitt2
TyroneBiggums
That was it. I was missing the redraw. I didn't know it existed.
I am using the setRenderer too if the symbol is a SMS. If the symbol is already a PMS, I just setUrl... both need redraw... apparently.
Thanks!
TimWitt2
No problem, I had the same issue until I decided to redraw
