Hi, On "Map Journal Builder", it is no longer possible to add a webpage in the "Main Stage" for anything other than the first slide. As for webpages I added in the past, some do connect, but I cannot see where to cancel or change them. Thanks!
Solved! Go to Solution.
Could you let us know which web URL you are trying to add, or give an example of one that doesn't work on the Main Stage.
In the Edit Section dialog, the Back button at the bottom to get back to the panel where the web page URL is shown:
Thank you ...
I am having the same issue in a sense. I've added webpages to mainstages, but they do not load. https://www.arcgis.com/apps/MapSeries/index.html?appid=6b61b3c17f60469da9eb82c92cc3f466
Some examples: Syria: The story of the conflict - BBC News
Syrian Journey: Choose your own escape route - BBC News
It says "no issue detected" but pages never load. This has been the case since February.
Kimberly,
Have you looked into AGOL Assistant?
It gives you a different control of the underlying code of your online maps and apps. Open it up and take a look at the JSON of your story map. You may be able to update your url/mainstage there.
Can you view this webpage outside of your story map?
If you are having trouble getting a web page or app to load inside a story map, please review the troubleshooting section of this blog for help on how to fix issues: Embedding apps and websites in Story Maps | ArcGIS Blog
Owen
