Search Widget. How to change "Find address or place"
2649
02-29-2016 06:42 AM
LianaSmith
Occasional Contributor II
I am using Search Widget in my Application in order to search by municipality or commission district. Is there any way I can change the grey text inside Search field "Find address or place" to "Find municipality, commission district or address"?
Thanks!
RobertScheitlin__GISP
Diana,
  In that case you need to adjust the Search widgets style.css.
Open this file [install dir]\server\apps\[app#]\widgets\Search\css\style.css and add this rule:
.jimu-widget-search .arcgisSearch {
   width: 400px;
Diana,
   Sure in the Search widgets configuration UI you will find "Placeholder text for searching all: " this is where you need to add your desired text.
LianaSmith
Robert,
Thank you, but the problem is that if I do it like this, the box is not long enough to have all words in it..
Is there anyway I can make it longer? Thank you!!!!
Diana,
   width: 400px;
LianaSmith
It worked. Thank you so much Robert. You are great
