raster extraction
2103
02-25-2016 02:21 PM
InceptionWoznicki
I have a original tif file which has values from 2 to 28. From that original tif file, I am extracting cells having value >=10 using the following code. The code is working. However, when I open the new extracted tif file in GIS, I found that the cell values range from 10 30 instead of 10 to 28. I would really appreciate any help/ suggestion!
The code is provided below:
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
#Set environment settings
env.workspace = "C:/Subhasis/Highland/Project/Python_data"
outws="C:/Subhasis/Highland/Project/Python_data/HSA_10"
#checkout ArcGIS spatial analyst extension license
inraster = arcpy.ListRasters("*", "TIF")
for i in inraster:
    flds = ("VALUE", "COUNT")
    dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(i, flds)}
    sumcnt = sum(dct.values())
    dct1 = {k:v for (k,v) in dct.items() if k >= 10}
    sumcnt1 = sum(dct1.values())
    percentage=(float(sumcnt1)/float(sumcnt))
    print i,percentage
    newraster = ExtractByAttributes(str(i), "VALUE>=10")
    outname=os.path.join(outws,str(i))
    newraster.save(outname)
SteveLynch
for testing purposes I'd include (see highlighted 3 lines)
for i in inraster:
    print i,percentage
  arcpy.CalculateStatistics_management(str(i))
  maxValue = arcpy.GetRasterProperties_management(str(i), "MAXIMUM")
    print maxValue
and the same for newraster
DarrenWiens2
MVP Honored Contributor
Is the 30 actually in the data, or just listed as the upper limit in the symbology?
InceptionWoznicki
No, 30 is not in the data. The upper limit is 28.
SteveLynch
for i in inraster:
    print i,percentage
    print maxValue
