OBJECTID values in Oracle
3646
02-24-2016 07:14 AM
AndrewRudin
Occasional Contributor III
Where do OBJECTID values on a feature class in Oracle come from when inserts occur?  Is it a sequence somewhere, or does ArcMap scan to find the current maximum ID and do a +1 operation before the insert?  In my situation the feature class is versioned and uses ST Geometry.
The feature class also has archiving enabled, so does the GDB_ARCHIVE_OID value on the archive table use the same mechanism to create OBJECTID values when records are inserted there when edits are posted to default?
by Anonymous User
Not applicable
Dear Andrew
I am not sure but I think that each layer/table registered with the geodabase has its own Oracle sequence for obtaining the OID value. Sequences are named "RXXX" where XXX is the value of the REGISTRATION_ID field related with an specific table/layer in the SDE table TABLE_REGISTRY .
Regards
Jesús de Diego
by Anonymous User
Not applicable
Dear Andrew
Regards
Jesús de Diego
George_Thompson
Esri Frequent Contributor
Look at the MINIMUM_ID field in the TABLE_REGISTRY
System tables of a geodatabase stored in Oracle—Help | ArcGIS for Desktop
-George
--- George T.
VinceAngelo
Esri Esteemed Contributor
It's a bit more complicated than just a sequence, because sequence generation is too slow for bulk insert processes.  Instead, the sequence has an interval (size dependent on version) for a gap in values and a pipe is used to store the next value when a cursor is shut down.  When the next cursor comes along, it will fetch off the pipe before consulting the sequence, to prevent a gap.  If you shut down the instance, the DBMS_PIPE objects are lost, resulting in a gap in subsequent inserts (though there is a [somewhat elderly] KB document that addresses a workaround).
- V
