AnsweredAssumed Answered
Service incorrectly transforming GeoRSSLayer outSpatialReference
Question asked by crozzy on Feb 22, 2016
We have a georss feed from a service where the coordinates are not correctly transformed to NZTM values.  Reading the API you can specify an out Spatial Reference.  This would be great but the conversion uses a utility at ArcGIS.com does not convert correctly. So when added to a JavaScript map the features do not display in the correct location.
This can be seen where a similar value is presented by using the conversion utility
: http://utility.arcgis.com/sharing/rss  and entering values:
This should return values in the ranges:
XMin: -1360246.4528216124
YMin: 4396622.905393021
XMax: 6334822.058701608
YMax: 7307344.9424917605
Spatial Reference: 2193  (2193)
but instead returns values in the range:
...,{"geometry":{"x":-2.9159042233687764E8,"y":1.0E7}...
Has anyone else had any problems with this.
Outcomes
