AnsweredAssumed Answered
zoom into the map
Question asked by aditi92roy on Feb 21, 2016
Latest reply on Feb 22, 2016 by aditi92roy
Hello ,
I am getting a problem in plotting the graphics and zoom into the feature on the map. Here below is my code. Please help. The data is getting populated into the grid and after that it is not zooming into the map.
define([
        "dojo/_base/declare",
        "dijit/_WidgetBase",
        "dijit/_TemplatedMixin",
        'dijit/_WidgetsInTemplateMixin',
        'dojo/_base/lang',
        "esri/tasks/query",
        "dojo/text!/Widgets/SearchButton/SearchButton.html",
        "xstyle/css!/Widgets/SearchButton/css/StyleSheet.css",
        "esri/Color",
        "esri/tasks/locator",
        "esri/InfoTemplate",
         "esri/symbols/Font",
         "esri/symbols/TextSymbol",
          "dojo/_base/array",
          "dojo/number",
          "dojo/parser",
           "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
            "esri/graphic",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleMarkerSymbol",
        "dojo/on",
        "dijit/form/Button",
        "esri/geometry/Point",
        'require',
        "dojox/widget/Standby",
        "dojo/_base/window",
        "dojo/window",
        "dojo/dom",
        "dojo/dom-attr",
        "dijit/registry",
        "dijit/form/NumberTextBox",
        "dijit/Dialog",
        "esri/tasks/geometry",
        "dojo/domReady!"
], function (declare, _WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin, lang, query, template, widgetCss,
Color, locator, InfoTemplate, Font, TextSymbol, array, number, parser, FindTask, FindParameters, connect, DataGrid, ItemFileReadStore,
         Graphic, SimpleLineSymbol, SimpleFillSymbol, SimpleMarkerSymbol, on, Button, Point, require,
  Standby, win, window, dom, domAttr, registry, NumberTextBox, Dialog,
       Geometry) {
    var imageUrl = require.toUrl("./images");
    var searchDialogbox;
    var center, zoom;
    var grid, store;
    return declare([_WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin], {
        // widgetsInTemplate: true,
        templateString: template,
        map: null,
        Map: null,
        imageUrl: imageUrl,
        findParams: null,
        searchDialogbox: null,
        findtask: null,
        searchText: null,
        spatialReference: null,
        featureUrl:null,
        map: this.map,
        //doFind:null,
        postCreate: function () {
        findtask1: function () {
            this.findtask = new FindTask("http://");
            this.findParams = new FindParameters();
            this.findParams.returnGeometry = true;
            this.findParams.layerIds = [0];
            this.findParams.searchFields = ["OBJECTID","FEEDER_NAME"];
            this.findParams.outSpatialReference = this.map.spatialReference;
            console.log("find sr: ", this.findParams.outSpatialReference);
        doFind: function () {
            //Set the search text to the value in the box
            this.findParams.searchText = this.ownerName.value;
            this.findtask.execute(this.findParams, lang.hitch(this, this.showResults));
        showResults: function (results) {
            console.log(results);
            this.map.graphics.clear();
            var symbol = new SimpleFillSymbol(
              SimpleFillSymbol.STYLE_SOLID,
              new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
              new Color([98, 194, 204, 0.5])
            //create array of attributes
            var items = array.map(results, function (result) {
                var graphic = result.feature;
                console.log(graphic);
                graphic.setSymbol(symbol);
                this.map.graphics.add(graphic);
                return result.feature.attributes;
            console.log("alertqb");
            var data = {
                identifier: "OBJECTID", //This field needs to have unique values
                label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                items: items
            //Create data store and bind to grid.
            store = new ItemFileReadStore({
                data: data
            var grid = registry.byId("grid");
            grid.setStore(store);
           grid.on("rowclick", lang.hitch(this, this.onRowClickHandler));
            console.log("rowclick");
            //Zoom back to the initial map extent
            this.map.centerAndZoom(center, zoom);
        onRowClickHandler: function (evt) {
            console.log("1");
            var clicked = evt.grid.getItem(evt.rowIndex).OBJECTID;
            console.log('clicked');
            var selected = array.filter(this.map.graphics.graphics, function (graphic) {
                return ((graphic.attributes) && graphic.attributes.OBJECTID === clicked);
            console.log('clicked20');
            if (selected.length) {
                this.map.setExtent(selected[0].geometry.getExtent(), true);
                console.log('clicked25');
Outcomes
