Hi all,
With Collector users can access the Runtime GDB on the devices collected through iTunes (for iOS).
Is it possible with Survey123 to do this? I had a look through iTunes (Apps > File Sharing > Survey123) and there doesn't appear to be any files accessible to do this.
Using the latest build of Survey123 (1.2.19) iOS
Solved! Go to Solution.
Hi John,
Survey123 for ArcGIS does not use the ArcGIS Runtime. You will not find a Runtime GDB. All you will find is a handful of SQLLite databases. If you are interested in developing with Survey123 for ArcGIS, have a look at AppStudio for ArcGIS. We will shortly announce how you can extend and customize Survey123 for ArcGIS with AppStudio for ArcGIS.
Ismael
Hi John,
Ismael
