Taking Tiled Layers stored on AGOL Offline
1907
02-19-2016 09:29 AM
DougComer1
I know this was not possible in the past. Is it now? I am getting errors about tile being unavailable at different levels.
If transferring a tile package manually the only work around?
Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi Doug,
It's possible to use tiled layers in offline.  You must using at least ArcGIS Server 10.2.2 and have the option 'Allow clients to export cache tiles' enabled.
https://doc.arcgis.com/en/collector/windows/create-maps/offline-map-prep.htm#ESRI_SECTION1_AB1D69C1F...
DougComer1
Hi Jake,
Thanks for this. We are not using server, only ArcGIS Online. Do you know if this functionality exists for ArcGIS Online hosted Tile Packages?
JakeSkinner
Yes, you can take hosted tiled services offline as well.  To create the tiled service, go to the Tile Package and you will have a PUBLISH option.  This will create the tiled service.  You can then enable this for offline use as well:
SubuSwaminathan1
Jake,
We have a hosted tile layer (State Plane coordinate system) and I don't even see the 'enable offline option' for it. I am trying this in March 2016 after the leap day AGOL update.
OfflineTilehostedLayermissing.jpgAny suggestions!!
