I downloaded the latest version of the LocalLayer widget (1.2.2-last upated on 11/17/2015). I am attempting to use it with WAB 1.3 and am finding some issues.
Is version 1.2.2 compatible with WAB 1.3?
Eric V
Gurnee, IL
Eric V
Gurnee, IL
Hi Robert,
I have made the 2 tweaks to the code (config.json & LayerInfos.js).
Creating a new app results in the following view in the Widgets tab - I cannot "edit" the LocalLayer widget.
The LocalLayer widget shows up as "6"....when I click on it, it pops up the widget list....none of which are the LocalLayer widget
Eric,
Sounds like you need to go to this url and follow the steps for setting up the widget
Because from the looks of it you have something wrong in the setup.
I went back and did a fresh "install" of WAB1.3, and made the appropriate changes to the 2 files - but this time I changed the config.js file in the "Default" app under the "predefined-apps" folder. My last attempt I only updated the config.js under the stemapp folder. I then created a new application and the widget showed up properly.
Eric,
I have it working just fine in WAB 1.3 after follow the advice in this thread:
Re: LocalLayerWidget and AccessifizrWidget
