ArcGIS Initializing License Issue
4223
02-13-2016 07:14 AM
AndreiStefan2
I have a single use license of ArcGIS Desktop Advanced 10.3.1 running on a 64 bit Windows 10 Pro. I didn't have any issues with the software so far until I tried to create a Python Add-In Toolbar... After I successfully installed the new created toolbar, neither ArcMap, ArcCatalog or ArcScene won't start at all. When I try to open one of the applications the initial small window appears with Initializing License... and it gets stuck like this. I have to stop the application from the task manager to close it. I uninstalled the software, deleting all the remaining files and registries, and reinstalled it and nothing changed. Also I read that I should have deauthorized the licenses before uninstalling which I admit I didn't. Now I am trying from the ArcGIS Administrator to deauthorize the licenses to make a new clean install, but this application get's stuck too when I try to authorize/deauthorize or check license availability.
Did someone have the same issue or can help, please? Thank you!
Andrei Stefan
AndreiStefan2
Thank you very much for the response! Unfortunately in the end I had to contact my local Esri representative to fix the issue. Apparently it was a license problem.
