eSearch Query on Multiple Fields
2015
02-10-2016 10:59 AM
TomLeMahieu
Can eSearch be configured to search on multiple fields from the same layer?  For example, in the configuration, can it search on both parcel number (PIN) and school?  I tried this but eSearch just hangs when I add the School Expression.
"expressions": {
  "expression": [
  "alias": "PIN",
  "textsearchlabel": "Search by PIN",
  "values": {
  "value": [
  "fieldObj": {
  "name": "PIN",
  "label": "PIN",
  "shortType": "string",
  "type": "esriFieldTypeString"
  "valueObj": {
  "value": ""
  "prompt": "PIN is",
  "textsearchhint": "enter PIN number here.",
  "sqltext": "Upper(PIN) = Upper('[value]') OR Upper(KEYPIN) = Upper('[value]')",
  "operation": "stringOperatorIs"
   "alias": "SCHOOLDESCRIPTION",
  "textsearchlabel": "Search by CVT",
  "values": {
  "value": [
  "fieldObj": {
  "name": "SCHOOLDESCRIPTION",
  "label": "SCHOOLDESCRIPTION",
  "valueObj": {
  "value": ""
  "prompt": "SCHOOLDESCRIPTION is",
  "textsearchhint": "enter SCHOOLDESCRIPTION number here.",
  "sqltext": "Upper(SCHOOLDESCRIPTION) like Upper('[value]')",
RobertScheitlin__GISP
Tom,
   Are you manually editing this json? It appears so because if you use the widget setting UI it would have added an "operator": "AND" property to the SCHOOLDESCRIPTION expression value.
Yes, the widget can definitely handle multiple fields in a query.
Tom,
TomLeMahieu
Robert,
Yes I was configuring it manually. I put it back into the configurator which added the "operator" property.
It all works well now! Thanks!!
tom
TomLeMahieu
Nevermind!! I just didn't configure it correctly.
