Idea-Suggestion / Map Notes, ArcGIS Online
1996
02-10-2016 09:27 AM
AntonioSaavedra
Hello!
I would like to know from fellow colleagues your opinion about if this is the best platform (Map Notes) to use for this map. I created the Boy Scouts of America Scouting for Food Map for Circle Ten - Golden Arrow District (Plano, TX) to use to manage the Scouting for Food Territories that each unit is assigned.  See map:http://www.arcgis.com/apps/Viewer/index.html?appid=09a216b22a414e1280f47a6a96233e50
How it works, each unit is assigned a territory and they are in charge of dividing the territory among the scouts that are volunteering, on Week 1 - Scouts Distribute the bags to each house in their territory this bags will be use to collect the food and Week 2 - Scouts will collect the bags with non-perishable foods from each house in the territory assigned to them and then take them to the collection points to be sorted and given to the local food pantries.
The map worked well since it was the first time that the District could visualize the map online and use from any device. Scouts and Leaders where able to interact with the map rather than looking at a paper map. If the Unit Leader needed to make copies of their area they where able to print. For many years this task was done by paper that contained outdated information and it was hard to update to distribute to all.
My questions are or features that I need?
  1. It will be nice if I can place a label in each territory so its easy to identified without using the map contents but Map Notes don’t allow for that, How I can do it?
  1. It will be nice if I can move the Collection Points layer to the top but Map Notes don’t allow me to do that.
  1. I need to have each territory selectable (layer) so users can turn off/of.
  1. It will be nice if I can have a flag that can turn on when a territory have drop off their non-perishable food.
  1. Would it be better to create each territory in ArcGIS Pro and then publish to ArcGIS Online? Would that use a lot of credits? How will be the more efficient way to publish the layers individually or as a group?
  1. Would like to add a photo to when users click on the Collection Points like a Story Map.
  1. Do you have any suggestions on how I can make it better, perhaps using a different approach, technique, app or application?
Thanks very much!!!
Carlos Saavedra
AlexanderNohe1
Occasional Contributor III
I am not entirely sure.  Someone from customer service may be able to better assist you with this.  You may also want to consider an ArcGIS for non-profit plan if you intend to only use this for the Boy Scouts of America.
AlexanderNohe1
Since you have a short time line, I think this might be a suitable suggestion for next year... but I believe that AppStudio would be a great solution for you all to pursue.  You could create a feature service that your scouting leaders could access and change the status of as they complete streets that you have assigned to them via teams.  You could also dynamically change the team that is assigned and the way that is symbolized on the map.  This is one of those projects that I think is wonderful to pursue and you can provide live updates on via the map.
AntonioSaavedra
Thanks very much! I am not familiar with App Studio, I will read on that and learn how to use. By any chance do you know if available for home/personal licenses?
AlexanderNohe1
