Streaming a Freehand 'Polygon'
2163
02-10-2016 07:46 AM
AmandaBreitling
Is there a way, when streaming on the collector app, to make a boundary without straight edges? Is there a parameter I have to place on the shapefile so when it is uploaded to a map it is forced to be freehand? We want to walk a perimeter of an excavated area that does not have straight edges yet the app continues to force it into a polygon. Any suggestions would be appreciated!
JakeSkinner
Esri Esteemed Contributor
Hi Amanda,
You should be able to set this in the web map.  After you click on 'Edit', you should see 'Manage' at the bottom of the Add Features pane.  After clicking on Manage, click the dropdown next to the layer > Properties:
You will then have the ability to set the edit tool:
I believe this will rollover to Collector, but haven't tested it, yet.
AmandaBreitling
I will try this out! I didn't even think to look for the options in the web map version.
Thanks!
Kylie
by Esri Regular Contributor
When you are streaming, vertices are being captured based on a time and distance interval (taking into account how far you have moved, and how long since a vertex has been captured). This will create a polygon, but it should be creating one that matches the boundary of where you are walking. Could you show me a screen shot of what you are seeing in Collector? If you aren't getting as many vertices as you'd like, you can adjust the streaming interval in the settings. This will cause vertices to get added more often. I believe the default is every 5 seconds, but you can make it every second.
Esri Education Team
AmandaBreitling
Kylie,
Unfortunately I did not save the test run I did on collector. I changed the streaming interval so hopefully that will help. Next time we use it I will be sure to share it with you.
Thanks for the advice!
