I recently created a Mosaic Dataset in a FGDB and loaded USGS High Resolution Orthoimageries into it. It is fine and fast but on certain areas the overviews seem not to work properly, as shown in the file attached. However, if I zoom in, the Orthoimagery do appear at certain scale...
Is there anything wrong in my workflow?
Hi
It looks like some of your overviews are not good since the real data looks fine.
When you see nothing try to use selecet visible rasters (left mouse on layer in ArcMap). If overviews exists (but the raster is white) you should delete these overviews (use remove rasters with OBJECTID value) and try to recreate only the missing tiles.
