sde_client
3763
7
02-05-2016 05:20 AM
LauraSimonetti
What do you know about sde_client files?  I’ve read a bit about them but I would like to know more.  I have a *huge* folder on my computer that contains a ton of these files. Can you clear them out?  Do you have to keep them?
Thanks!
ChristopherThomas
New Contributor III
Laura,
It's possible that you may have some sde log files enabled that are writing to that folder. What kind of extension does the file name have?
If you check your environment variables for the machine do you see any variables created named SDEINTERCEPT or SDEINTERCEPTLOC?
-Chris
LauraSimonetti
Thank Chris!
JakeSkinner
Esri Esteemed Contributor
Hi Laura,
SDEINTERCEPT files help identify performance issue.  These files do not need to be kept.  Below is a helpful KB article with more information:
35704 - Diagnose ArcSDE connection and performance issues using SDEINTERCEPT
LauraSimonetti
Thanks Jake.  I'll take a look at that article.
MichaelVolz
The KB article only shows support up to v10.2.  Has this functionality been deprecated at v10.3.x?
VinceAngelo
The entire 'C' API was deprecated at 10.2, and no longer ships as of 10.3.
VinceAngelo
It's certainly not the default behavior to create trace or intercept logs from ArcSDE 'C' API based applications.  If you or your IT staff haven't taken proactive steps to generate these logs, then whomever created the application may have left in more debug code than is good for overall system stability.  It certainly hurts client performance to log every action every time a function is called.
- V
