AnsweredAssumed Answered
WAB 1.3 edit widget not moving points - Attrib edit OK.
Question asked by mravichandran on Feb 3, 2016
Latest reply on Feb 5, 2016 by mravichandran
Dear Readers,
thank you for taking the time to read this posting:  I had downloaded WAB 1.3.  after successfully adding a SQL Spatial point layer to ArcMap, I had published map and feature services from the same map document.
To use it WAB, I had created a new Web Map and consumed the feature service.
After creating a new website with edit widget, the editor was able to change the attributes of the point feature but could not move - I went back and checked to see whether the 'disable geometry change' check box was checked = true by mistake. Not it was not checked = true.
So attribute changes were recorded and were verified from another machine.  I am not able to move the point to a new location,
any help or suggestion would be greatly appreciated.
regards
ravi.
Outcomes
