AnsweredAssumed Answered
Problem loading custom dijit
Question asked by davidchrest on Feb 3, 2016
Latest reply on Feb 3, 2016 by davidchrest
Hello, I am having a serious problem trying to figure out how to load (dojoConfig) a custom dijit. There seems to be very little straightforward documentation on this. I am using Nicolas Haney's wonderful Select by Attributes Dijit found here: developer-support/web-js/select-by-attribute-widget at master · Esri/developer-support · GitHub
I copied code to my PC and all works well.
He loads the widget from a Dropbox URL like this:
var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
  var dojoConfig = {
  packages: [{
  location: "https://dl.dropboxusercontent.com/u/79881075/SelectByAtt/"
In the README.md, he says, "Configure the dojo loader to pull from the widget's location:"
  var dojoConfig = {
  packages: [{
I have AttributeSelection.js in my /js file. I have tried many things but cannot get it to load the widget from my own directory instead of his dropbox URL.
This also does not work:
dojoConfig = {
    packages: [
                 location: location.pathname.replace(/\/[^\/]*$/, '') + '/js'
Can somebody please help me with this tricky syntax to load the widget from my own folder.
Thank you so much for any help,
David
Outcomes
