I am looking at the 'share on twitter' links for my app and I notice that before the actual URL, which looks good, the name of my app is not correct. I cannot find where in the application the old name of my app is still referenced.
Example- the twitter link that is generated is here:
2016 CLRP test http://my.app.com/ #storymap
the name of my app is not "2016 CLRP Test"-- that was the name of my story map that I initially created on AGOL and have since renamed. I looked in the index, config files, etc and cannot find any reference to this ghost of a name. And my AGOL content does not have that name anymore either. I am using this map journal app that references my AGOL story map so I can still edit it online in the builder. everything seems cool except this weird thing.
Ideas? bug? help! I'd like to use these share links on my app but want the title to be obviously correct. thanks
Are you hosting the application on your server?
Can you post a picture of your problem?
I found out that this is a bug in the app that will be addressed at the next release. So when you press the Twitter 'share' button, the name of the app only references the original name of your app. If you change it (via ArcGIS online, for example), the app does not recognize that change. the app developers recommended changing the app name via the AGO Assistant or through the code in a hosted app.
