Custom Info template window
1875
5
02-01-2016 10:01 AM
KushendraShah1
New Contributor III
I have an issue with  info template window. I used set content method to display calculated value by geometry engine service. It works fine for displaying calculated value but cannot join other fields information. Here is my code:
var template = new esri.InfoTemplate();
         template.setTitle("<b>Cooperator: </b> ${Cooperator}");
         template.setContent("<b>PropertyName: <b> ${PropertyName} <br>");      // this cannot be displayed
         template.setContent(getTextContent);
var layer = new FeatureLayer("URL", {
          infoTemplate: template,
          outFields: ["*"],
          opacity: 0.5
        // convert squarefeet to acre
        function getTextContent(value) {
  var sqft = geometryEngine.geodesicArea(value.geometry, "square-feet");
  var squarefeet = number.format(sqft, { places: 1 });
  var acres = number.format(sqft / 43560, { places: 0 });
  return "Acres :" + acres ;
        map.addLayers([layer]);
TracySchloss
You'll need to create your entire formatted string within your function.
function setContent(value)  {
var formatString = "<b>Property Name:  </b> + value.attributes.PropertyName +"<br/>"
formatString += "Acres:  " + acres;
  return formatString;
TracySchloss
KushendraShah1
New Contributor III
Tracy, Thanks for the information. Unfortunately, it didn't work. It returns all the field string except the calculation. I think that calculation didn't executed when we call the function. Please check here;
         template.setContent;
function setContent(value){
  var formatString = "<b>Property Name:  </b> + value.attributes.PropertyName + <br/>";
  formatString += "acres:  " + acres;
TracySchloss
When you define your infoTemplate content with a function, you have to pass it the name of your function.   it should be:
template.setContent(setContent)
OR whatever you have called your function.  I name my function something else to avoid confusion.
If you're not sure of your calculation, set some breakpoints within that function and make sure you have a value.  If you're not getting a value for sqft, then yes you're likely to have problems with what the function is returning.  There are a variety of reasons why this might not return the right output, including failing to define geometryEngine somewhere higher up in your code.
KushendraShah1
New Contributor III
Tracy, you are right! I am glad that works now. Thank you so much for the help. Appreciated!
var PropertyString = value.attributes.PropertyName;
  var formatString = "<b>Property Name:</b> " + PropertyString
  formatString += "<br><b>Acres:</b> " + acres;
TracySchloss
You must also define number.  Once I added 'esri/geometry/geometryEngine', and 'dojo/number' along with  their properly placed variables, your formatting function worked for me.
