get rest service value to html text
1842
01-29-2016 01:23 PM
EvanSepa
I couldn't find info on how to query a rest service to get a value and put it into text on a webpage . . . using js / html
The solution here seems straight forward
jQuery > REST > ParksFinder Bonus?
However I'm looking to grab just one item value... something like this
$(document).ready(function()
    $.ajax ( {
  type: 'GET'
  url: 'https://ww3.yorkmaps.ca/arcgis/rest/services/Transportation/YR_TrafficCameras/MapServer/0/query​​?where=LOCATIONID%3D **JSVARIABLE** &f=json'
  data: { get_param: 'value' },
  dataType: 'json'
  success: function (data) { $.each( data.features, function(index, element) {
  $('classname').append($('<div>' + element.attributes.CAM_LOCATION + '</div>') );  } ); } } );
I think the success parameter configured correctly would give me something useful...?!
Any guidance would be greatly appreciated.
Cheers.
RobertScheitlin__GISP
Evan,
      Here is that code modified to use a url parameters:
HTML:
<!DOCTYPE html>
<html>
<head>
  <title>Traffic Camera List</title>
  <script src="https://code.jquery.com/jquery-1.12.0.min.js"></script>
  <script src="trafficrest.js"></script>
</head>
<body>
  <div>
    <p>Welcome to the Traffic Camera List.</p>
  </div>
</body>
</html>
JS:
$(document).ready(function () {
  var getUrlParameter = function getUrlParameter(sParam) {
    var sPageURL = decodeURIComponent(window.location.search.substring(1)),
      sURLVariables = sPageURL.split('&'),
      sParameterName,
      i;
    for (i = 0; i < sURLVariables.length; i++) {
      sParameterName = sURLVariables.split('=');
      if (sParameterName[0] === sParam) {
        return sParameterName[1] === undefined ? true : sParameterName[1];
  $.ajax({
    type: 'GET',
    url: 'https://ww3.yorkmaps.ca/arcgis/rest/services/Transportation/YR_TrafficCameras/MapServer/0/query?wher...' + getUrlParameter('location') + '&spatialRel=esriSpatialRelIntersects&outFields=*&returnGeometry=true&returnDistinctValues=false&returnIdsOnly=false&returnCountOnly=false&returnZ=false&returnM=false&f=json',
    data: {
      get_param: 'value'
    dataType: 'json',
      $.each(data.features, function (index, element) {
        $('body').append($('<div>' + element.attributes.CAM_LOCATION + '</div>'));
Example:
Evan.html?location=41
ChadKopplin
Occasional Contributor III
You could run a query geoprocessing service, and publish this service then you can use the query in your app.
Evan,
HTML:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
  <div>
  </div>
</body>
</html>
JS:
      sParameterName,
      i;
  $.ajax({
    type: 'GET',
    data: {
      get_param: 'value'
    dataType: 'json',
Example:
EvanSepa
Thanks.
I added ...
    $('.title').append($('<div>' + element.attributes.CAM_LOCATION + '</div>'));
    $('.camid').append($('<span>' + element.attributes.LOCATIONID + '</span>'));
    $('.position').append($('<span>' + element.attributes.CAM_POSITION + '</span>'));
    $('.lat').append($('<span>' + element.attributes.LATITUDE + '</span>'));
    $('.long').append($('<span>' + element.attributes.LONGITUDE + '</span>'));
    $('#refimgid').attr('src', './loc' + element.attributes.LOCATIONID + 'R.jpg' );
so it outputs various attributes to various locations in my html...
Cheers.
