Is there method to change the pop-up window size in WAB?
2920
01-28-2016 03:29 PM
LeiZhou1
Is there method to change the pop-up window size in WAB Developer Version? The pop-up window is set up in the web map, then the web map is set up in WAB Developer Version.  The pop-up window content can be controlled but it does not allow users to change its size. What if I want to make it bigger? Should I go to search anywhere in jimu.js folder? Thanks!
YueWu1
by Esri Regular Contributor
Hi Lei,
You can take a look about this thread. WAB - popup box inconsistent sizes
YueWu1
Hi Lei,
LeiZhou1
Thanks a lot!
