Shortlist Map not loading externally
1808
01-27-2016 08:28 AM
CynthiaMatney1
    Hello.  I'm not sure the issue here.  I have created a shortlist map for our city parks and internally everything seems to work fine.  Externally however, I'm not that it either just spins and never loads or it comes up with Error 404 - File or Directory Not Found.  I'm including the link if anyone can give me some insight that'd be great!
http://maps.ci.liberty.mo.us/ParksShortlist/
Thanks!!!
Cynthia
RupertEssinger
That ParksShortlist folder either doesn't exist on your web server or has not been made public. For example I can get to here: https://maps.ci.liberty.mo.us/    and access the other entries, but not ParksShortlist or Parks ShortlistOld.
I found the web map your Shortlist is using in ArcGIS Online and I see the same issue if I open it in our Shortlist test instance: http://storymaps.esri.com/templates/shortlist/?webmap=c120aa2ad75c45769a4637db74324606&DETAILS_PANEL...
The web map opens OK but none of the images are accessible because they are also in your inaccessible ParksShortlist folder:
https://maps.ci.liberty.mo.us/ParksShortlist/resources/images/Pictures/PlaceLibSignPGHor.jpg
So it's not an issue in the Shortlist app, it's an issue on your server to look into.
Rupert
RupertEssinger
Rupert
CynthiaMatney1
Thanks for the heads up!  It's been a while since I had added a new map on our city web server (been doing mostly ArcGIS Online maps) and so had forgotten that after I add it to the wwwroot folder that the IT guy has to then add it to our proxy server!!!  It works now!!!
Thanks!
RupertEssinger
Glad that it is working now. Nice work by the way: http://maps.ci.liberty.mo.us/ParksShortlist/
