Can someone tell me where I can find the GPS Toolbar in Arcgis Pro?
I can't find any option for real time GPS in Arcgis Pro.
Thanks for any help
Thanks for any help
Hi Dan,
thanks for your help. I can't understand why I do not get the freedom to work with GPS in any application I like.
I would like a better implementation of GPS in ArcGIS not only in collector. Maybe I missed something.
Best regards
Uli
I can't put my hands on the ArcGIS Pro 1.2 update notes.
Don't forget ArcGIS Pro
Put in suggestion
I think an implementation of real time GPS in a GIS software should be there, In particular if you want to work in the field with external GPS devices and tablets with a larger screen. So if that comes in ArcGIS Pro 1.2 update, fine.
you could check here to see if it is currently suggested...currently under consideration... or post it as an ideas Esri Arcgis Ideas | Ideas Submission Portal that is pretty well all the options open ...wait or expedite. good luck
Have a look ... Tools that are not available in ArcGIS Pro—Appendices | ArcGIS for Desktop
But there are gps tools
An overview of the From GPS toolset—Conversion toolbox | ArcGIS for Desktop
but if you search "gps toolbar" only arcmap 10.3.1 shows. so I am not sure if this is what you want... or I can't find it either.
