is it possible to run an ArcObjects add-in as a Windows scheduled task?
4605
01-18-2016 09:26 AM
AndreaLugli
I am writing because I am wondering if it is possible to run an ArcObjects .NET add-in as a Windows scheduled task.
I have written some code in VB.NET through ArcObjects and then I prepared the add-in using Visual Studio.
It works fine in ArcGIS desktop but now I need to run it automatically every night as a scheduled task.
I know that it is possible for Python scripts ... maybe wrapping the .NET add-in inside a Python script?
Andrea Lugli (Italy)
Tags (1)
FreddieGibson
Occasional Contributor III
Technically yes...but it would make more sense to migrate your logic to a construct that would be easier to run headlessly, like a standalone console application (i.e. exe) or gp service. If you must run the logic as an addin then you'd need to write an additional application to automate driving a session of ArcMap so that you can get a hook into your addin content and interact with it as needed.
The following two pages would get you started.
Automating the ArcGIS Desktop Application
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/#/Automating_the_ArcGIS_Desktop_ap...
How to create an application to run on a schedule
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//0001000002nt000000
ChrisSmith7
If it's an exe, I would check out Schedule a task - Windows Help
Keep in mind some pitfalls others have encountered:
ArcObjects fail when running scheduled task
FreddieGibson
