Identify related point by polygon feature
2222
01-18-2016 07:13 AM
MeganGosch
I am trying to create the functionality so that when a user clicks on a polygon, it's related point feature is highlighted on my web app map.  There is a similar JS api located under the Geoprocessing - Point in polygon search, but it's not exactly what I'm looking for, and it's also not in a widget form.  I'm new to programming, with very limited skills, so wanted to see if anyone has created anything like this already.  Thanks!
https://developers.arcgis.com/javascript/jssamples/util_relation.html
Geoprocessing - Point in polygon search | ArcGIS API for JavaScript
JordanBaumgardner
Occasional Contributor III
I don't think there is anything out of the box. eSearch widget [ rscheitlin/eSearch · GitHub  ] is probably the closest. It allows for a search based on a geometry drawn by the user.
I think what your looking for is a Query. It can accept a geometry and return features found with in.
Query | API Reference | ArcGIS API for JavaScrip
Or possibly a relationship query.
RelationshipQuery | API Reference | ArcGIS API for JavaScript
This sample seems close - You simply replace your circle geometry with your polygon.
Select with Feature Layer | ArcGIS API for JavaScript
All of the above would take some programming.
MeganGosch
Thanks, all very close.  The only issue is that each point has many polygons 1:M relationship.  So the point may actually not be in the polygon itself, but contains the attribute of the related polygon so the query has to occur on that.  I just haven't been able to figure it out.
