AnsweredAssumed Answered
Network Analyst - Pyhton export sublayers to a FeatureClass, each one.
Question asked by jgarcinuno on Jan 15, 2016
Latest reply on Jan 19, 2016 by FGibson-esristaff
This is my problem: How I can export to a feature class my sublayer Routes from outNALayer.
I been able to export just the tabular data but NOT the geometry. Down below is the code or part of the script.
# Process: Create a Closest Facility Layer. Optimize on Travel Time but  compute the distance traveled by accumulating the meters attribute.
    outRouteResultObject = arcpy.na.MakeClosestFacilityLayer(Transportation_ND, "Closest_Facility", "Miles", "TRAVEL_TO", "", "1", "Miles", "ALLOW_UTURNS", "Oneway", "NO_HIERARCHY", "", "NO_LINES", "", "NOT_USED")
    print "Creating Closest Facility Layer"
    # Get the layer object from the result object. The route layer can now be referenced using the layer object.
    outNALayer = outRouteResultObject.getOutput(0)
    print "outNALayer : " + str(outNALayer)
    # Get the names of all sublayers within the route layer.
    subLayerNames = arcpy.na.GetNAClassNames(outNALayer)
    print "subLayerNames : " + str(subLayerNames)
    # Store the layer names that we will use later - Facilities
    facilityLayerName = subLayerNames["Facilities"]
    print "facilityLayerName : " + str(facilityLayerName)
    # Store the layer names that we will use later - incidents
    incidentsLayerName = subLayerNames["Incidents"]
    print "incidentsLayerName : " + str(incidentsLayerName)
    routeLayerName = subLayerNames["CFRoutes"]
    print "routeLayerName : " + str(routeLayerName)
# Process: Add destination points.
    arcpy.na.AddLocations(outRouteResultObject, facilityLayerName, Facilities, "", "1000 Meters", "", "test_area SHAPE;Transportation_ND_Junctions NONE", "MATCH_TO_CLOSEST", "CLEAR", "NO_SNAP", "5 Meters", "INCLUDE", "test_area #;Transportation_ND_Junctions #")
    print "Adding Faclitities to the Closest Facility layer"
    # Process: Add Origin points.
    arcpy.AddLocations_na(outRouteResultObject, incidentsLayerName, Incidents, "", "1000 Meters", "", "test_area SHAPE;Transportation_ND_Junctions NONE", "MATCH_TO_CLOSEST", "CLEAR", "NO_SNAP", "5 Meters", "INCLUDE", "test_area #;Transportation_ND_Junctions #")
    print "Adding Incidents to the Closest Facilty layer"
    # Process: Solve
    arcpy.na.Solve(outNALayer, "SKIP", "TERMINATE", "")
    print "Solving the Problem"
     RoutesSubLayer = arcpy.mapping.ListLayers(outNALayer,routeLayerName)[0]
    print "Selected sublayer : " + str(RoutesSubLayer)
        #arcpy.FeatureClassToFeatureClass_conversion(RoutesSubLayer, network)
Outcomes
