when using the Bower arcgis-js-api package, what controls the install directory?
2727
01-17-2016 09:55 PM
JohnCartwright
Hello All,
I notice that when using Bower to install a local copy of the ArcGIS for Javascript API, it sometimes installs into the ./dist directory and sometimes into a ./bower_components directory.  It's not clear to me what influences this.
Can someone please explain?
Thanks!
--john
ReneRubalcava
That is controlled via a .bowerrc file.
If you use the sample app on github, it will install into a src directory because we set that up.
jsapi-resources/.bowerrc at master · Esri/jsapi-resources · GitHub
If you just do a bower install arcgis-jsp-api without the .bowerrc file, it will install into bower_components/arcgis-js-api.
We recommend you set up a bower.json ahead of time to install it into an esri directory, to make it easier to use.
  "name": "arcgis-js-api-sample-app",
  "version": "1.0.0",
  "license": "Apache-2.0",
  "dependencies": {
  "esri": "arcgis-js-api#3.15.0"
  "resolutions": {
  "dojo": "v1.10.4/esri-3.14.0"
You can see this in the demo apps here.
jsapi-resources/bower at master · Esri/jsapi-resources · GitHub
Hope that helps!
ReneRubalcava
  "version": "1.0.0",
  "dependencies": {
  "resolutions": {
Hope that helps!
JohnCartwright
Thanks Rene, that helps.  I was on the lookout for a .bowerrc file in my project directory but didn't realize that a .bowerrc in the parent directory would also be used and that was the source of my confusion.
--john
