I have two TIF images which have these colour bands as their symbology:
I want to combine the two TIF images and for the final product to have the same symbology.
I created a dataset but the symbology looks like this:
and the image is all black.
Is it possible to combine TIF images and have the symbology in the 3 bands?
How you go forward will depend upon what software you are using, how your data is set up, and what you are trying to achieve.
So, to help out responders:
1. What software do you have available? ArcMap? And what Version?
2. Do you have access to any extensions? Specifically Spatial Analyst or 3D Analyst?
3. Do your tiffs have a coordinate reference system (crs) assigned?
4. Are your tiffs located spatially next to each other and you want to combine them into one? Or instead are they overlapping and you want to come up with an output tiff that combines the values of the two originals?
5. Do your tiffs have similar value ranges or are they vastly different? For example, one has a range of zero to ten, while other has a range of zero to 255 - that would make them different.
If you can answer these questions, that would help greatly in providing answers that will be useful.
Chris Donohue, GISP
1. ArcMap 10.2.2
2. Yes, I have Spatial Analyst and 3D Analyst
3. Yes, they have spatial reference (WGS 84 Web Mercator)
4. They are located next to each other and I want to combine them into one
5. Both have a range of 0 to 255.
You could create a mosaic dataset in ArcCatalog and add the above rasters to it.
Edit: Creating a mosaic dataset—Help | ArcGIS for Desktop
The choice really depends on what you need there are choices such as
Mosaic To New Raster—Help | ArcGIS for Desktop
or Mosaic—Help | ArcGIS for Desktop
if you don't want a mosaic dataset Add Rasters To Mosaic Dataset—Help | ArcGIS for Desktop
