Creating a map of defined Postcode Sectors
4867
6
01-14-2016 02:39 AM
JamesChard
Hi all,
quick newbie question:
Is it possible to create a basemap of the UK showing only certain specific postcode areas:
  1. CB
  2. CO
  3. IP
  4. NR
  5. PE
  6. SG
  7. SM
  8. SS
I need to create this primarily to print and stick on the wall. To my constant shame!
James
DanPatterson_Retired
do you have the data? Or are you looking for it?
JamesChard
Hi Dan,
No, I don't have the data, other than those are the only postcode areas I'd like to display
BenLeslie1
Occasional Contributor III
You can download postcode sector data from the ONS website:
Office for National Statistics
Just search for poscode - there are two variations released each month - you'll have to search for the documentation if you want to read up about the differences but from your question it sounds like either will do; just go for the latest version.
JamesChard
Thanks Dan, that looks just the ticket!
Well ... I just googled and came up with a large number of hits.  You can explore, but if you can even get the data in shapefile format that will be a start... for example, here is one link Data | Open Door Logistics
XanderBakker
Esri Esteemed Contributor
If you download the data from the link suggested by Dan (http://www.opendoorlogistics.com/wp-content/uploads/Data/UK-postcode-boundaries-Jan-2015.zip , do read the usage terms) there will be 3 shapefiles in the ZIP:
Areas, Districts and Sectors.
Depending on the level of detail required, you can directly use the areas using a definition query:
"name"  in ('CB','CO','IP','NR','PE','SG','SM','SS')
For Districts and Sectors you will probably have to create an additional text field, fill it with: left( [name], 2) and then point the definition query shown above to that new field.
Example (areas in black, districts in blue and sectors in red with labels):
source: Open Door Logistics | Specialists in open source solutions for transport logistics
Areas:
