AnsweredAssumed Answered
TOC for arcgis javascrip API
Question asked by Adityakumar529 on Jan 14, 2016
Hi All,
I was working on TOC for Javascript api where I am using the widget.
http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109
But sometime the layer will come and some times its not showing.And I am confused what url to use while calling the toc widget.
Following are the code I used.
var dojoConfig = {
        packages: [{
            parseOnLoad: true,
            "location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs' // for xdomain load
  map.on('layers-add-result', function (evt) {
                  var toc = new TOC({
                      map: map,
                      layerInfos: [{
                          layer: Dream_2D,
                          title: "UI-E Layer",
                          collapsed: true,
                          slider: true
                          layer: GSI_2D,
                          title: "2D GIS",
                          collapsed: true,
                          slider: true
                           layer: GSI_3D,
                           title: "3D GIS",
                           collapsed: true,
                           slider: true
                          layer: base_layer,
                          title: "Base Layer",
                          collapsed: true,
                          slider: true
                          layer: satellite,
                          title: "Satellite",
                          collapsed: true,
                          slider: true
                  }, "layerList");
                  toc.startup();
Any suggestion on this will be helpful.
Aditya
Outcomes
