AnsweredAssumed Answered
Points of printed webmap are displayed wrong
Question asked by matthias_gerke on Jan 13, 2016
Latest reply on Jan 13, 2016 by matthias_gerke
I have a problem when printing a webmap with the javascript api for arcgis. The printTask function is working correct but the points of the printed map are displayed different to the webmap.
Webmap (correct):
Printed map (wrong):
The renderer of the pointLayer uses the sizeInfo attribut which represents a distance quantity:
var sizeInfo = {
            field: function (graphic) {
                var caseCount = getCaseCountByAssigneeIds(graphic.attributes["assigneeIds"]);
                if (caseCount) {
                    return 50 * Math.sqrt(caseCount) / 3;
                } else {
                    return 0;
            valueUnit: "meters",
            valueRepresentation: "radius",
Here the print command:
var printTask = new PrintTask("..");
var params = new PrintParameters();
params.map = map;
params.outSpatialReference = map.spatialReference;
var template = new PrintTemplate();
template.exportOptions = {
    width: 1280,
    height: 720,
    dpi: 300
template.format = "pdf";
template.layout = "A3 Landscape";
template.preserveScale = true;
template.layoutOptions = {
    scalebarUnit: "Kilometers",
    legendLayers: []
params.template = template;
printTask.execute(params, function (res) {
    window.open(res.url);
}, function (err) {
    debugger;
It seems the valueUnit (meters) will be not converted correct. Any ideas? Did i forgot settings?
Thanks for help!
Outcomes
