AnsweredAssumed Answered
Parse data from JSON service in several txt files
Question asked by ivandorte on Jan 8, 2016
Latest reply on Jan 10, 2016 by xander_bakker
I'm new in JSON and Python, I need to parse rainfall data from json hyperlinks that I saved in a shapefile.
This shapefile was created from a JSON service (http://www.sir.toscana.it/archivio/dati.php?D=json_stations ) that contain X, Y coordinates of gauge stations and an hyperlink of rainfall data for each gauge station. This is the result:
Now I want to create a script to save data contained in each link in a new text/csv/xls file using CODICE field as name for each output file. Or, if possible, save all the rainfall data (Stored in "SerieDati" --> "Valore") for each station (named "Codice" in json file) in an unique txt file in this format:
This is the model builder:
but i don't now how to finish my script.This is the script for one station...
import arcpy, sys, os, json, urllib2
urlink = arcpy.GetParameterAsText(0)
json_string = urllib2.urlopen(urlink).read()
data = json.loads(json_string)
#I want to print results for each station...
sys.stdout = open("C:\\Users\\ivn\\Desktop\\prova.txt", "w")
precip = data['properties']['SerieDati']
for i in precip:
print i
#And then...
This is the output for one station :
{u'TipoValore': u'V', u'Data': u'2000-02-23 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-02-24 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-02-25 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-02-26 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-02-27 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-02-28 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-02-29 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-03-01 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-03-02 09:00:00', u'Valore': u'28.8'}
{u'TipoValore': u'V', u'Data': u'2000-03-03 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-03-04 09:00:00', u'Valore': u'0.0'}
{u'TipoValore': u'V', u'Data': u'2000-03-05 09:00:00', u'Valore': u'0.0'}
How to remove {,},u,' characters from output?
And this is JSON data for one station:
http://www.sir.toscana.it/archivio/dati.php?IDST=pluvio&D=json&IDS=TOS19000114
{"type":"Feature","geometry":{"type":"Point","coordinates":[11.6617,42.8829]},"properties":{"Codice":"TOS19000114","Nome":"Abbadia S. S. - Laghetto Verde","Comune":"Abbadia S.S.","Provincia":"SI","Quota":"910.00 mslm","UnitaMisura":"mm","TipiValore":{"N":"Non Validato","P":"Prevalidato","V":"Validato","@":"Mancante","R":"Ricostruito"},"TipoDati":"PLUVIOMETRIA - Aggregazione a 24 ore (9-9)","SerieDati":[{"Data":"2012-01-01 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-02 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-03 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-04 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-05 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-06 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-07 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-08 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-09 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-10 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-11 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-12 09:00:00","Valore":"","TipoValore":"@"},{"Data":"2012-01-13
THANKS!
Outcomes
