Set spatial ref of a geoJSON polygon feature
4775
10
01-07-2016 12:38 PM
JamesCrandall
MVP Frequent Contributor
Tag: Please help Jason Scheirer
After running down the path of geoJSON, I've finally encountered some difficulty in setting the spatial reference on a polygon feature.  In the code below, I thought I could get away with somehow setting the spatial ref on arcpy.AsShape() method but now I'm stuck on what to do!
The problem seems to be that my polygon.projectAs(outSr) is not working, I presume because the input polygon feature does not have the inSr set?
polygon = arcpy.AsShape(v)  # <-- does not have a spatial ref at this point
prjpolygon = polygon.projectAs(outSr)
Input JSON coordinates are web Mercator (Auxiliary Sphere).
Hopefully I'm just missing the obvious.
data = {}
feature_info = """[{"rings":[[[-9020934.359395614,3186437.9104202176],[-9020934.359395612,3186323.2548777903],[-9021029.90568097,3185711.7586515094],[-9021794.27596382,3185941.0697363648],[-9020934.359395614,3186437.9104202176]]]}]"""
def geo_convert(ring_string):
    from json import loads, dumps
    rings = loads(ring_string)
    feat_coll = {'type': 'FeatureCollection',
                 'features':[]}
    for ring in rings:
        feat_coll['features'].append(
            {'type': 'Feature',
             'geometry': {
                'type': 'Polygon',
                'coordinates': [ring['rings'][0]]
    return dumps(feat_coll)
tmpArr = []
jsonFrmt = geo_convert(feature_info)
jsonData = json.loads(jsonFrmt)
inSr = arcpy.SpatialReference(3857)
outSr = arcpy.SpatialReference(26758)
for key,value in jsonData.iteritems():
    if value == 'FeatureCollection':
        pass
    else:
        for i in value:
            try:
                for k,v in i.iteritems():
                    if k == 'geometry':
                        polygon = arcpy.AsShape(v) #cannot set a sr
                        #project to output sr
                        prjpolygon = polygon.projectAs(outSr) #does not project
                    else:
                        pass
            except:
                pass
DarrenWiens2
MVP Honored Contributor
If you're going to use projectAs, it needs to be on a polygon-by-polygon basis, not the list:
>>> inSr = arcpy.SpatialReference(4326)
... outSr = arcpy.SpatialReference(3857)
... features = []
... features2 = []
... feature = [[1,2],[2,2],[2,3],[1,2]]
... polygon = arcpy.Polygon(arcpy.Array([arcpy.Point(*coords) for coords in feature]), inSr)
... polygon2 = polygon.projectAs(outSr)
... features.append(polygon)
... features2.append(polygon2)
... arcpy.CopyFeatures_management(features,r'in_memory\poly')
... arcpy.CopyFeatures_management(features2,r'in_memory\poly2')
BruceHarold
Hi
You need to make a geometry instance from the array you get out of the geometry feature made by AsShape().
The spatial reference is read only with any geometry object.
If your geometry collection is all polygons then AsShape(<geojsondictionary>,False) should make a multipart polygon.
If you have a big GeoJSON handling problem then consider the Data Interoperability extension, it can read GeoJSON input and write Esri geometry with less pain :-).
Regards
BTW, Jason S. no longer works here
JamesCrandall
That's what I hoped to accomplish but I don't see how to do this with a polygon!  Do you have an example to point to?
Thanks a bunch for your input!
I can get to populate "features" array, but not sure why it won't set to a polygon
        pass
    else:
        for i in value:
            try:
                    if k == 'geometry':
                        features = []
                        featureinfo = v['coordinates']
                        for feature in featureinfo:
                           features.append(arcpy.Polygon(arcpy.Array([arcpy.Point(*coords) for coords in feature]), inSr))
                        prjpolygon = features.projectAs(outSr) #fails
BruceHarold
Hi
Here is a code snippet:
I found a multipart polygon from some polygon features I had laying around:
with arcpy.da.SearchCursor('Suburbs','shape@') as cursor:
    for row in cursor:
        gj = row[0].__geo_interface__
        if row[0].partCount > 1:
            print('Biggie')
            break
Biggie
The variable 'gj' now has GeoJSON in it.  Grab the array from geometry made from it and create a new geometry with a spatial reference
aPoly = arcpy.Polygon(arcpy.AsShape(gj,False).getPart(),arcpy.SpatialReference(2193))
Check the spatial reference:
aPoly.spatialReference.name
'NZGD_2000_New_Zealand_Transverse_Mercator'
Regards
JamesCrandall
Edit: Bruce -- thanks for your input and example, I'll be able to use this elsewhere I'm sure!  I should have posted the full implementation so that you didn't have to guess but I think Darren supplied the exact example I needed.
Thanks again.  I'm not understanding your example.  Where is that SearchCursor set from?  I don't have a FeatureClass, just an input JSON string that I need to take in, create the polygon feature of those coordinates, change the spatial reference and then return the coordinate pair of the centroid and the area of that feature.
BruceHarold
Hi, the SearchCursor was just fo rme to get hold of a feature to create GeoJSON.
I guess you're dealing with that as an input.
JamesCrandall
Hi Bruce,
Yes, again -- apologies for not posting my complete implementation and just offering bits and pieces.  This is all supposed to be lightweight operation and just deal with geometries minus any feature classes and cursors.
Thanks again for your input!  I learned some things!
DarrenWiens2
... features = []
... features2 = []
JamesCrandall
Edit: the issue is an extra "[" and "]" at the start and end of the input array of coords.  Super easy to miss with all of the brackets and squiglies but your "feature" array shows the differnce!
Your example input of coords:
My input looked like this:
feature = [[[-9020934.359395614, 3186437.9104202176], [-9020934.359395612, 3186323.2548777903], [-9021029.90568097, 3185711.7586515094], [-9021794.27596382, 3185941.0697363648], [-9020934.359395614, 3186437.9104202176]]]
But to remove/fix the offending brackets, I had to modify my geo_convert def that takes in the input json string and handles it.  It was an easy fix to apply to the 'coordinates' token:
                 'features':[]}
    for ring in rings:
            {'type': 'Feature',
             'geometry': {
                'type': 'Polygon',
                'coordinates': ring['rings'][0] #<- this had an extra set of [] wrapping it
    print feat_coll
#the input string I am getting
#format the string
Darren,
I'm getting a RuntimeError "Point: Input value is not numeric" on this line:
Here's my input JSON:
This is what feature looks like when I print it:
Any ideas?
features = []
features2 = []
feature = v['coordinates']
print feature
print polygon.area
print polygon2.area
JamesCrandall
In case my last reply is confusing, Darren's suggested example seems to be what I needed.
FYI for others: this is largely an issue of JSON string manipulation work and can be tough to pick out the error in the details.  Keep in mind that it's often a good idea to reduce things down to bare minimum, get it working, then apply it to the full implementation -- something easily skipped (like I tend to do!).
