AnsweredAssumed Answered
How do I convert some region of MapView to the vector image in ArcGIS Runtime SDK for WPF?
Question asked by dyanos on Jan 7, 2016
I want to convert some region of MapView to the vector image file with high resolution in ArcGIS Runtime SDK for WPF.
First, I used RenderBitmapTarget API supported by .NET SDK. RenderBitmapTarget API has two arguments related to DPI.
However, I failed to get a high resolution image from MapView, because when I used some DPI value, the result was applied all controls except mapview. The size of MapView was equal before applying some DPI value.
Second, I found exportMapImage API. However this api may only use on javascript of Esri Runtime SDK.
Do you have any idea to solve this problem?
Outcomes
