Export GeoPackage
3117
01-08-2016 04:48 AM
AntonBakker
I am trying to export a shapefile to GeoPackage with the help of this code snippet​. But when I execute the code (as an extension in ArcMap 10.2.2).  I receive the following message. The implementation I used can be found here (in VB.NET), build with ArcObjects SDK 10.2.3552
Error exporting data.
The application is not licensed to create or modify schema for this type of data
DBMS table not found
I could not find any documentation on the Sqliteworkspacefactory, and what license is required to write to sqlite. Can anyone enlighten me on this topic? Much appreciated.
DuncanHornby
MVP Notable Contributor
Anton,
At what point does the error occur? Is it the connection to the geopackage or when the ExportOperation is run? May be IExportOperation does not support sqlite? If it is the export step that is throwing the error may be you could try calling the GeoProcessing tool FeatureClassToFeatureClass?
Duncan
