Roberts Custom WAB Widgets
2330
01-07-2016 02:37 AM
JayakrishnanRadhakrishnan1
Robert Scheitlin, GISP We are in process of developing an ESRI Map viewer application using .Net and ArcGIS JavaScript API. We were facing map freeze issues while using Google street view in the map. As an alternate we tried integrating Google Street View Widget 1.3 from the ESRI community to our application but we failed in doing so. Can you please guide us or give us some insight into how this can be integrated into our system.
RobertScheitlin__GISP
Jayakrishnan,
   The widgets code has many dependencies on the Web AppBuilder and would have to be extensively re-written to able to be used in a none WAB app. I don't have any guidance for your use case.
RebeccaStrauch__GISP
Is there a reason you aren't trying to use the Web AppBuilder developer edition? As Robert mentioned, his and other user custom widgets are built to plug into thIs program.  See Web AppBuilder Developer Edition - Customization Resource List​ for available widgets and Tips and Observations for getting Web AppBuilder -  Developer Edition Installed
there is is a dependence on ArcGIS Online or Portal, but the web site can be hosted locally.
