arcpy.AsShape() Concerns with .getArea() and .area
3560
01-06-2016 08:03 AM
JamesCrandall
MVP Frequent Contributor
In an attempt to acquire the area of a polygon feature, I'm seeing some discrepancies between two methods and need some input.  In the code below, I'm acquiring what I think is the area in 2 distinctive ways (parea1 and parea2):
prjpolygon = polygon.projectAs(outSr)
parea1 = prjpolygon.getArea()
parea2 = prjpolygon.area
The result:
parea1 Sqfeet : 21767057.9882
parea2 Sqfeet : 26642367.0
Why do these return different values?  Which one do I use?
WesMiller
Regular Contributor III
You've probably already looked here Polygon—Help | ArcGIS for Desktop
area
(Read Only)
The area of a polygon feature. Empty for all other feature types.
Double
getArea ({type}, {units})
Returns the area of the feature using a measurement type.
WesMiller
area
(Read Only)
Double
JamesCrandall
Thank you!
I had to cycle thru the types (planar was the ticket) to get these to produce identical results:
parea1 = prjpolygon.getArea('PLANAR','Feet')
print "\t parea1 Sqfeet : {} ".format(parea1)
print "\t parea2 Sqfeet : {} ".format(parea2)
Results:
parea1 Sqfeet : 26642367.0
