AnsweredAssumed Answered
Problems Creating a Time Aware Map Service
Question asked by timdunlevie on Jan 6, 2016
Latest reply on Jan 6, 2016 by mike.robb
Hi all,
I have built a MXD which I use to create a feature service to our ArcGIS server for use in our internal web client.
All feature classes reside in our SDE (sql server).
One feature class is time-enabled based on a "date_stamp" field (date type).
Using the slider in ArcMap is shows monthly updates of the data. It all works fine.
If I leave the time slider on the latest month of the dataset I am able to identify only this month of the dataset in ArcMap.
I want the service to show the latest data in my web map and then have the user use the slider to interrogate the data as-needed.
However, when I publish the service it shows me ALL months in my dataset - it displays the data cumulatively (which I have un-ticked in the layer properties). For example, if I identify the data in our web map, it will list ALL "date_stamps" of the published feature Class.
Is there a way for the service to publish and only show the latest month as I see it in ArcMap ?
We are using 10.3.
thanks
Outcomes
