Getting Extents of Runtime geodatabse
3207
7
01-04-2016 08:13 PM
Bhargav_KumarK
I created runtime geodatabase in Arc GIS Desktop and using in Arc GIS Qt application. One of my requirements is that I need to get extents of this runtime geodatabase, how to achieve this?  When I created feature layer from run time geodatabase and printing its extent it is giving total extent of map
but not only the extent of  geodatabase.
Regards,
Bhargav
LucasDanzinger
Esri Frequent Contributor
It works for me. Here is my code. Maybe you can try this and see if it works for you?
import QtQuick 2.3
import QtQuick.Controls 1.2
import ArcGIS.Extras 1.0
import ArcGIS.Runtime 10.26
ApplicationWindow {
    width: 500
    height: 500
    Map {
        anchors.fill: parent
        FeatureLayer {
            featureTable: gdbFeatureTable
    Geodatabase {
        path: "~/ArcGIS/Runtime/Data/BirdSightings.geodatabase"
    GeodatabaseFeatureTable {
        geodatabase: gdb.valid ? gdb : null
        featureServiceLayerId: 0
        onGeodatabaseFeatureTableValidChanged: {
            console.log("Gdb feature table is initialized.")
            console.log(JSON.stringify(gdbFeatureTable.extent.json))
LucasDanzinger
Bhargav-
The extent shouldn't be on the Geodatabase itself, but rather on one of it its feature tables. Maybe once you load the feature layer with one of the feature tables, instead of printing out the extent of the feature layer, you print out the extent of the feature table.
Luke
Bhargav_KumarK
When I am printing extent on feature table it is not giving valid output. It is giving 'nan'  if I am printing any extent values of feature table.
LucasDanzinger
Hmm, I am printing out the extent no problem with the Damage Inspection geodatabase that comes in the SDK sample data folder. Maybe you could try using some sample data to determine if it is an issue with the code or with the data somehow.
-Luke
Bhargav_KumarK
I am also getting extents printed with Damage Inspection geodatabase. So the problem is with my data. How to create runtime geodatabase such that I get extents in Qt Application? In my case while creating geodatabase, it has extents. One more thing is that what ever the extents I am getting for Damage Inspection geodatabase in Qt Application they  are not matching with values I saw for Damage Inspection geodatabase in Arc GIS Desktop.
LucasDanzinger
I'm not sure why there is a difference. Maybe you can try re-creating your geodatabase and see if it works? Otherwise, it could be a data specific bug that we are not aware of. Perhaps you could contact support and troubleshoot this with them?
ZdeněkJankovský
Hi all,
is there something new in this?
I have offline *.geodatabase package exported from ArcGIS Desktop 10.3.1 and reading the featureTable Extent in AppStudio with:
var table = gdbModel.geodatabaseFeatureTableByLayerId(j);
var extent = table.extent.clone();
give me the nan values as well.
Thank you,
Zdenek J.
LucasDanzinger
import QtQuick 2.3
ApplicationWindow {
    width: 500
    height: 500
    Map {
        FeatureLayer {
    Geodatabase {
